Re: Farmall F-12 update and more problems..
Posted by FarmallCT on April 28, 2014 at 03:07:51 from (70.215.9.58):
In Reply to: Re: Farmall F-12 update and more problems.. posted by rustred on April 27, 2014 at 18:10:43:
Okay, thanks. I will try that. Probably should have also mentioned that i have to start it in the run position because it runs rough in advanced position. It's timed barely after TDC to prevent risk of kickback. Is it advised to push the timing back to right on TDC? Now that i think about all the problems and how it sounds a bit off, it might be part of the problem. Thanks.
