Re: IH 2544 Shifting
Posted by mkirsch on April 28, 2014 at 04:46:46 from (65.199.189.6):
In Reply to: IH 2544 Shifting posted by IH2544 on April 27, 2014 at 07:44:16:
The right shifting lever should move in a standard "H" pattern like a 5-speed manual transmission.
Pop the cap off the end of the base of the shift lever, and squirt some penetrating lube in there. Then gently work the shift lever back and forth, side to side, feeling for the "gate" where the lever can move sideways. Some wiggling, some jiggling, and maybe a good smack or two, with the penetrating lube, should knock the rust free.
We had the same problem with a recently-acquired 656 that uses the same shift mechanism. It was gummed up from sitting for several years.
