Re: farmall super c rear rim size
Posted by mkirsch on April 28, 2014 at 05:04:55 from (65.199.189.6):
In Reply to: farmall super c rear rim size posted by pmich61 on April 27, 2014 at 07:03:56:
You can also find out what you currently have on the tractor.
Stick a ruler through the gap between the rim and the hub, and align the end with the edge of the rim bead on the inside. Sight a measurement on the outside edge. A 9" rim should measure between 9.25" and 9.5". It measures 9" inside.
You want the vertical surface that the bead of the tire pushes against, not the lip.
Or you could make yourself a giant set of calipers out of cardboard.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
