Re: help troubleshooting missing MD
Posted by caterpillar guy on April 28, 2014 at 06:00:45 from (75.134.175.75):
In Reply to: help troubleshooting missing MD posted by mschwartz on April 27, 2014 at 23:39:33:
It sounds like one of the change over valves is stuck open. That will cause that. Ours will do that some times. If you take the tappet cover off and tap that valve it will probably help. Give it an oil change seems to help with that. If you could go work it hard like on a plow for a day or so it would probably clear it up. They need to run daily or those change over valves will stick like that. When we used ours to feed cows every day it would start fine even at -20. Might even be the only thing that did start.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
