Re: 826 international
Posted by mkirsch on April 28, 2014 at 06:05:39 from (65.199.189.6):
In Reply to: 826 international posted by jr1983 on April 27, 2014 at 19:34:48:
Are you pushing the position control lever for the 3pt ALL the way down?
There is a short section at the bottom of the position control labeled "RUN" as I recall. If you put the lever in that section it causes the rest of the hydraulics to not work.
