Re: Farmall C, Super A, 140, 200, etc. Hydraulic Pump Weak
Posted by mkirsch on April 28, 2014 at 12:56:23 from (65.199.189.6):
In Reply to: Farmall C, Super A, 140, 200, etc. Hydraulic Pump Weak posted by RTR on April 28, 2014 at 11:56:33:
You can't. That's the problem. Used pumps are a pig in a poke.
Then you usually pay 1/2 price of a new pump for a used pump with NO guarantee, and 9 times out of 10 they're just as bad as the one you took off. Now you get smart and buy a new pump, but you would've been way ahead if you'd bought the new pump in the first place.
This kind of hydraulic pump is two gears meshing together, a gear pump. Gear pumps get weak when the mesh of the gears gets loose, or the gears wear into the end plate of the pump, or seals/gaskets/orings allow pressure to escape past them.
New gaskets and seals may well be all your pump needs. For what it costs vs a whole new pump, it is worth it to try that route first.
