Re: 3pt sickle mower model?
Posted by Tractordanp on April 29, 2014 at 02:31:09 from (50.137.83.148):
In Reply to: 3pt sickle mower model? posted by Eldon (WA) on April 28, 2014 at 20:02:38:
Sounds like a number 100 balanced head mower I have 2 one
is fasthitch one is 3 point
On the fasthitch one the thing on left side goes under 3 point
arm and when adjusted correct it will lift bar when you pick
arms when down it will let the bar float
Very good mower only complaint I have with mine is if it gets
pluged up the mower runs so smooth it will not shake the plug
off like a old pitmen mower guess you can't call that a problem
Good luck dan
