Posted by The tractor vet on April 29, 2014 at 16:21:49 from (75.24.5.173):
In Reply to: SMTA hydraulic setup posted by Brady Miller on April 29, 2014 at 12:21:26:
1250 is what a good system will do and trying to push more you will most likely lean all about cam gear failure . You will be like the one guy around here that did away with the Hyd. unit under the fuel tank and made up a tank for the oil and ran everything from the pump to his valve set up . First time he use it when he went to lift the disc at the head land to turn he did not let off the handle of the valve fast enough and deadheaded the cylinder and before the relief valve opened to dump the pressure off his tractor just stopped dead. It would not restart and i get this call about his tractor died . So road call and start looking at his reenginering and had to look no further then the rotor , when you tried starting the tractor the rotor did not turn anymore . So a new set of cam gears and it was back running and i reset the regulator to 1250 and it was fine . On the OLD systems if what your trying to lift won't lift get a bigger cylinder or get a newer tractor with higher pressure hyd.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
