Stuck hydraulic coupling in 7140 magnum
Posted by Nathon on April 29, 2014 at 18:28:05 from (70.194.199.158):
I bought a new to me CIH 496 disc. I used it and when I went to unhook the hyd. Couplers from the rear remotes one has refused to allow me to pull it out. I have disconnected the hose from the cylinder so I am sure it has no pressure on it. The remote on the tractor had been working fine up till now. The sleeve inside the tractor coupler was replaced about two years due to hoses popping out. Do you have any ideas how I can get this apart and what might be causing the issue. Thanks in advance.
