Re: SMTA hydraulic setup
Posted by D Slater on April 30, 2014 at 05:45:08 from (184.14.195.235):
In Reply to: Re: SMTA hydraulic setup posted by sflem849 on April 30, 2014 at 05:00:04:
SMTA pressure relief is in the reservoir housing. Maximum pressure supposed to not exceed 1200 PSI on those.
That's why when IH added a remote control valve without a built in relief they teed the pressure line from the pump into the valve and on into the hydraulic unit. Also why the lever has a little latch on the side of the reservoir. Lever was latched back to keep the oil from circulating through the unit and back to the pump so pump pressure went to the remote control valve. Set up like that the factory relief valve worked for the control valve also.
Original poster could plumb the valve to use the same pressure relief if needed.
