Re: Best lawnmower EVAR?
Posted by Lmack on April 30, 2014 at 15:18:58 from (24.131.50.165):
In Reply to: Best lawnmower EVAR? posted by AlanA on April 30, 2014 at 11:38:53:
It all depends on how much you have to cut, how hard the ground is, and how open the area would be. The B will not have live PTO so the blade will stop for you to gear down or to reverse. You will not be able to ride the clutch in heavy grass or around tight spots. The best you will be able to do is to hit the heavy spots in first gear or possibly take a narrower swath. IF you have a wide open area on hard ground that you plan to keep cut on a regular basis then go for it. Otherwise get a zero turn 60" if you plan to use it commercially.
