Re: Super C engine ?s
Posted by Russ600 on April 30, 2014 at 17:07:32 from (162.212.68.75):
In Reply to: Super C engine ?s posted by montidale on April 30, 2014 at 16:15:40:
Hi
Sounds like you have this engine just about tore apart. I would check your sleeves and pistons for wear as well as the crankshaft. If those parts are within spec. put in new rings and bearings, and get the head done. Try Olsens gaskets for the O rings. Those super C engines are pretty tough. I have never had a problem with used parts that were with in spec. Good Luck.
Cheers Russ
