Re: Transmission slippage on 1086
Posted by mkirsch on May 01, 2014 at 04:58:27 from (65.199.189.6):
In Reply to: Transmission slippage on 1086 posted by Nathan on April 30, 2014 at 11:38:41:
Yeah, I don't know why most everyone is saying clutch, clutch, clutch, because that is the last thing that will slip on a tractor like a 1086. My money is on a bad TA. They ran it until one side went out, then ran it until the other side went out. On hydraulic TAs, when one side goes the other is not far behind.
The "cheap" thing to do right now is not turn a single frame bolt. Check the adjustments on the clutch and pressures on the MCV so you get a better idea of what's wrong, like tractor vet said. Splitting one of these is quite a bit of work, and no fun. You don't want to do it on a guess.
