Re: Center pivot pin in front axel 86 series
Posted by IaGary on May 01, 2014 at 05:50:47 from (108.160.236.246):
In Reply to: Center pivot pin in front axel 86 series posted by Larry B. 1486 on April 30, 2014 at 17:14:44:
There is or should be a 5/16 bolt about 6" long thru the pin from side to side on the big front cast piece.
If there is no bolt in the holes on the side of that cast piece then the bolt sheared off. It should drive right out with that bolt removed.
Jack the front up just enough to get the pressure off the pin first.
Gary
