If you have the IH type remote control valve to have pressure at the side ports. Lever on the control valve needs locked in the position so that the little latch under the lever will keep it from going to center. That keeps the oil from circulating back to the reservoir and having no pressure to the side ports. Then when you pull the pump rod back the hitch should raise and go down when the rod is pushed forward provided you have nothing hooked to the remote lines. Other port on the lift cylinders needs to breath with only one pressure line used. Or if you have double acting cylinders just use tees and plumb the remote control valve to the lift cylinders. That way you have up and down pressure. Trouble is you can't use both the 3 point and the remote control valve at the same time with that setup.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
