Re: 3 pt. hitch hookup on Farmall M
Posted by glennster on May 01, 2014 at 08:20:52 from (162.204.229.223):
In Reply to: 3 pt. hitch hookup on Farmall M posted by mikes54jubilee on May 01, 2014 at 05:40:00:
sounds like you have a christmas tree valve on the belly pump, giving you two way hydraulics. the two lines going to the rear of the tractor are the ones you want to use. tie the input lines going to the top of the 3 point cylinders together, and tee them in to one of the rear outputs, then tie the lower to inputs together and tee them in to the other rear outputs. that will give you two way hydraulics to the 3 point. i used pioneer couplers to make the rear output connections so the hitch can be dis-connected if need be. here are a few pics of my set up on my m. i have a char -lynn spool valve, instead of the christmas tree, but they work the same. there is a third hydraulic line on the back of my m, that is for one way hydraulics for a dump wagon.
third party image
third party image
third party image
third party image
oh, and the belt pulley is driving a 260 amp dc welder
third party image
