There is an o-ring at the bottom of the distributor. New part # is 86637641 at your favorite IH dealer. If you choose to remove the distributor, rotate the engine so the rotor is pointing to #1 on the cap; the timing pointer should be lined up with the TDC notch on the front pulley. Much easier to put back later.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
