Re: 51 SUPER C DISTRIBUTOR
Posted by mkirsch on May 01, 2014 at 11:33:30 from (65.199.189.6):
In Reply to: 51 SUPER C DISTRIBUTOR posted by PETE CORMIER on May 01, 2014 at 07:36:22:
No need to look at the flywheel.
If you shine a light down into the #1 spark plug hole you can SEE the piston come up to TDC.
Just remove the plug, stick your thumb over the hole, rotate until air starts pushing out, then watch it come up on TDC.
These engines turn easy enough you can rotate them with the fan as long as the belt's somewhat tight.
