Posted by Haas on May 01, 2014 at 13:43:14 from (50.142.111.41):
In Reply to: Woods L59 mower? posted by Keith Calhoun on April 30, 2014 at 14:28:04:
The mower deck will work, however the brackets will not. You will have to find brackets for the A. You did not say, but I hope you have a Super A as the bracket for an A will be different and not as easy to find. If there is a belt with the mower, it will work as the Cub and the Super A and140 use the same belt. The L 59 (L means left hand) is the usual mower for the Super A. The cub mowers are often right hand but either can be made to work. It's just how the belts are installed. Rotation can't be changed on the deck, as blade bolts on L mowers are LH thread and R mowers have RH threads to keep the bolts from coming loose.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
