Re: 656 gas want to put in 560 diesel engine in it
Posted by Baelee05 on May 02, 2014 at 07:09:19 from (166.147.104.158):
In Reply to: 656 gas want to put in 560 diesel engine in it posted by Eric in wi on May 02, 2014 at 05:37:51:
Unless the 263 is completely shot and the 282 is fresh rebuilt, I would forget it. Even when new the 282's can be problematic. The 263 is an easy rebuild. If you need a diesel tractor I would look for something a little later with a better engine.
