Re: 656 gas want to put in 560 diesel engine in it
Posted by mkirsch on May 02, 2014 at 10:01:19 from (65.199.189.6):
In Reply to: 656 gas want to put in 560 diesel engine in it posted by Eric in wi on May 02, 2014 at 05:37:51:
Pretty much... nothing.
The 656 has the smaller bell housing bolt pattern as the 460. Maybe the front mount will work, but everything in back is different.
You also might need different frame rails. On the bigger tractors the rear adapter plates are thicker on the diesels by about 1", and the frame rails are shorter by approximately the same amount.
