Sure it will Find the right front timing motor plate from a 282 diesel out of a 656 or 706 use the rest off the gas engine rear parts some throttle linkage and air cleaner from 706 or 656 D return from pump to tank.After thought bore two holes in the 656 frame rails were the front motor plate sets on top the frame on the 560.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
