You just measure the inside of the rim, between the beads. I would think the 15.5s might get you a bit more traction, they are the same height as a 13.6 but wider. My 300 has 14.9s which are taller and thus increase speeds slightly. I guess it is partly a matter of what you can find. If you are buying new then you could do anything. Zach
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
