Posted by used red mn on May 02, 2014 at 22:51:08 from (166.137.101.145):
In Reply to: 560 PS blew up! posted by oregonfarmer on May 02, 2014 at 12:47:03:
If you ABSOLUTELY need it you could TRY disconnecting the lines going to it and loop a hose between both the lines you unhook and the diconnected fittings on the box. This will keep dirt out of the box and allow fluid to circulate as you strong man the steering wheel. This may also greatly decrease the other hyd functions because the priority valve will be supplying the max amount of fluid to ps lines you unhooked and looped. I'm not sure what the results would be if you capped the supply lines. I would not recommend that. With the expanse of the fields I've seen photos of in Oregon I can't fathom anyone try to farm there in this day and age with a 560. That said I spent my share of time in the seat of a variety of Farmalls all with less than 65 horse back on the farm in KS. Good luck!
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
