Re: 656 gas want to put in 560 diesel engine in it
Posted by jiminy on May 03, 2014 at 03:11:59 from (216.227.83.23):
In Reply to: 656 gas want to put in 560 diesel engine in it posted by Eric in wi on May 02, 2014 at 05:37:51:
Just happen to be in the middle of a similar deal....only I am putting a 656 263 in a 560..only problem you should have is to just drill 2 holes in the top of the framerail for the front mountsas the later 656 mounts through the side...easy problem for you. I found out the hard way that the steering shaft on the 560 needs to go through where the later front mounts are..didn't discover it untill I was almost done ..or so I thought as it was about the last thing I had to do...oh well
