Re: differens between 886 and 1486
Posted by IaGary on May 03, 2014 at 04:23:55 from (108.160.236.246):
In Reply to: differens between 886 and 1486 posted by Kollebo on May 03, 2014 at 00:18:09:
The transmission and rear end are heavier built to handle the extra HP of the 1486.
Cat 3 3 pt on the 1486 instead of the Cat 2 on the 886.
Larger radiator on the 1486 as well. Usually larger tires on the 1486 as well.
About the only things the same are the tin work and cab.
Gary
