Re: differens between 886 and 1486
Posted by Owen Aaland on May 03, 2014 at 10:33:33 from (216.47.33.5):
In Reply to: differens between 886 and 1486 posted by Kollebo on May 03, 2014 at 00:18:09:
The main castings are all the same. Other than the 14 having a few heavier bearings, the TA, speed transmission, and range transmission are all the same. The ring and pinion may have different ratios though the replacement parts are all the same. The differentials are the same but the final drives are heavier. The brakes use the same parts but the 14 has more disks on each side.
