200 2 Point 2 Disk Plow
Posted by Lmack on May 03, 2014 at 19:05:56 from (24.131.50.165):
I did some plowing today with my 200 with a 2 disk mounted plow. I grew up with a 200 and a C-20 moldboard but I had no experience with a disk plow. I know you pull the stabilizer pins to let the moldboard float and I thought you would do the same for a disk plow. The area I needed to plow was small so I just left the stabilizer pins in. The disk plow worked much better with the pins in. It tends to pull too far to the left with the pins out. Do the disk plows not suppose to float?
