Re: m farmall coil hookup.
Posted by John T on May 04, 2014 at 12:19:36 from (216.249.72.121):
In Reply to: m farmall coil hookup. posted by crl800 on May 04, 2014 at 11:45:13:
If you're at Negative ground, power form IGN switch to coils +, and - terminal to distributor where it gets to ground when points are closed.
PS FYI there's actually NOT a discrete stand alone "resistor" tucked and hidden away inside that coil, it has no internal "resistor", it has a LV coil primary winding resistance in the 2.5 to 4 ohms or so range......
YES youre correct
John T
