Re: Still Missing Serial Number - Help!!!
Posted by Glenn on December 23, 2000 at 19:25:21 from (63.48.150.134):
In Reply to: Still Missing Serial Number - Help!!! posted by Glen 130 on December 23, 2000 at 17:38:48:
Hi again,
The numbers with the R in them are part numbers. The number you described as 22*8 or 22*B is indeed a casting code. It should be a B. The B indicates the year 1956, and the 22 indicates the day of the month(in this case, 22nd). There should be another number before the 22 with what kinda looks like a screw head between the two numbers. That will tell you the month. You may want to check some more castings for date codes(like the wheels or the engine block). They will be similar to the one you found in terms of format.
It looks like your 130 is a 1956 model, which was the first year of Farmall 130 production. There were only about 600 130s produced in 1956.
Post A Followup
: Re: Re: Still Missing Serial Number - Help!!!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
