Re: Farmall Super A 12v wiring
Posted by Luke0927 on May 04, 2014 at 19:48:23 from (99.104.196.26):
In Reply to: Re: Farmall Super A 12v wiring posted by Luke0927 on April 10, 2014 at 17:53:36:
I ended up just cleaning the terminals and replacing the positive and ground from the current wiring and fires up an runs great...I'm going to leave it as is through the gardening season and redo it all based on the 12v conversion on here. Which is similar just the current setup is using the original wiring from the 6v.
What about this and it has been this way, when I turn the swtich on the Amp meter goes to the right for charging, and when it starts it goes to the left. If I put the volt meter on it, it is really charging voltage goes up to about 13.6v.
Is the meter bad you think? I'll see what you guys thing then tell you a couple things I tried.
