Well whaddya know? I should've looked at the parts books on the rear cover. They are the same part number for gas and diesel.
Ok, that solves getting the engine hung in the tractor.
I would think you should be able to find a 656 diesel flywheel at a salvage yard somewhere. They're pretty common. Not sure I'd trust the gas flywheel to be balanced right or be heavy enough to withstand the diesel's pounding.
You may have to work on the governor, I think. The 560 runs the engine at 1800RPM, but the 656 is 2100 or 2400 IIRC.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
