Re: Farmall 100 tire
Posted by Paul from MI on May 05, 2014 at 18:27:44 from (204.106.248.120):
In Reply to: Farmall 100 tire posted by Jtky on May 05, 2014 at 18:19:54:
At a minimum you need to replace the tube, and thoroughly wash the inside of the tire to get all of the chloride out. Unless the additional traction is really needed, I'd have the chloride removed from the other tire too. Depending on how much rust you have around the valve stem the old rim can be repaired, or it may be cheaper to replace it. YT may have the part, check it out.
