Re: Identify front axle on an H
Posted by jal-SD on May 05, 2014 at 21:12:06 from (208.53.222.169):
In Reply to: Re: Identify front axle on an H posted by bassmasta76 on May 05, 2014 at 12:56:46:
Not a rare option, as explained below, these came
with a #24 mounted corn picker. The part you see
outside the cap are really extensions of the nuts
that hold the wheel bearings in place with a
different type of hub cap. You probably do not
have a bearing out, its most likely the seal on
the hub cap that has gone bad. Good luck finding
a seal, if I remember fight, they were raw hide.
If you want to replace them, you will have to find
a couple of nuts and new hub caps. I think I still
have the original nuts and caps that were on my
Dad's H before it became his picker tractor
someplace. I still have the tractor and it still
has the #24 picker hub caps on it. (My $0.02
worth. jal-SD)
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
