Re: 560D wide front question
Posted by mkirsch on May 06, 2014 at 04:35:19 from (65.199.189.6):
In Reply to: 560D wide front question posted by 1949H on May 06, 2014 at 04:33:39:
Unfortunately, no.
The 350 is a narrow-frame tractor, and the 560 is a wide frame, so the bolt holes for the saddle won't even come close to lining up.
What happened to the M front end?
This post was edited by mkirsch at 04:36:15 05/06/14.
