400 Carburetor
Posted by xrcr on May 06, 2014 at 04:43:56 from (208.64.54.130):
Can only get to run on choke. Have had off and cleaned since tractors been sitting for 15yrs. I"m thinking float and needle valve are not doing what they should. I know float sticks open occasionally since gas will start pouring out when not running until you tap on carb. Any insight is appreciated.
