Re: H Carburetor.
Posted by rustyfarmall on May 06, 2014 at 06:42:01 from (208.126.186.41):
In Reply to: H Carburetor. posted by bassmasta76 on May 06, 2014 at 06:20:33:
I've rebuilt a BUNCH of H carburetors. You are correct with those 2 different models. The 2 models are basically the same. Only difference I could ever see was that MAYBE the main metering stem for the distillate/kerosene model MIGHT have had larger holes in it.
Since distillate is no longer available, and kerosene is really not an option either, it only makes sense to use the kit for the 50981 gasoline carburetor. That kit will work just fine for the 45108 carburetor, and then it will be all set and ready to go for gasoline.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
