Posted by rvirgil_KS on May 06, 2014 at 07:28:19 from (8.36.247.230):
In Reply to: Starting my 300U posted by Danby on May 05, 2014 at 22:10:45:
Do you actually have spark?
Check for power at the coil. Should have near battery voltage at input to coil. Wire from coil to distributor should have near battery voltage with points open and zero volts with points closed.
Remove center wire from distributor and set it close to engine block. When you crank engine with switch on a strong spark should jump a quarter inch gap.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
