Re: Oil Pressure Drops
Posted by John G. Hasler on May 06, 2014 at 10:43:47 from (174.124.115.121):
In Reply to: Re: Oil Pressure Drops posted by wayne in mn on May 06, 2014 at 10:28:22:
> Older engines especially do not need much oil
> pressure; what is more critical is the volume of
> oil supplied.
Hydrostatic bearings don"t work without sufficient pressure. Also, at 5psi most of the oil is probably going out through the first bearing it gets to, leaving very little for the others.
