Re: 560 rpm ?
Posted by pete 23 on May 06, 2014 at 17:09:18 from (74.33.89.148):
In Reply to: 560 rpm ? posted by tbish on May 06, 2014 at 15:14:00:
The max high idle is 1965 + or - a bit. This gives you 1800 rpm when engine is pulled to where governor contacts smoke screw if all is good. First thing to do is make sure the throttle linkage pulls the lever on pump to the stop screw.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
