Re: W4 rear wheels
Posted by molly on May 06, 2014 at 19:00:44 from (209.103.250.220):
In Reply to: W4 rear wheels posted by Dozinhal on May 06, 2014 at 18:06:24:
I used 2 large thick pieces of square tubing to make a x shape and threaded rod with double nuts to hold everything to the cast center of the tractor and a 40 ton bottle jack. it came off. put something over the threads on the axel to not mess them up.
I might have a picture
