Re: More ph out of farmall H
Posted by D Slater on May 07, 2014 at 04:59:04 from (184.14.195.235):
In Reply to: More ph out of farmall H posted by Rustyparts on May 06, 2014 at 19:07:24:
If sticking with the same block, some options.
See if the H block bore is good enough to fit 3-9/16 pistons form a overbore SH or standard bore 300 engine with filler rings in the counter bore. Use the 300, 350 head gasket. Bore the block about 1/16 and put 3-5/8 dia. 350 pistons in.
Bore H block about 1/8 bigger and use SH sleeves. Bore H about 3/16 bigger and use 300 and 350 3-5/8 piston and sleeve set.
Depending on the block, some may run into trouble with the last two options.
