Re: Farmall H governor bearings
Posted by rustyfarmall on May 07, 2014 at 05:54:06 from (208.126.186.41):
In Reply to: Farmall H governor bearings posted by farmall_h_1944 on May 06, 2014 at 19:47:41:
If there is very little side to side or back and forth movement, you should be good to go.
