The 656 does have two pumps mounted piggy back. There is a difference though from the older 560 for example. On the 560 the main pump feed the aux system and the smaller piggy back pump is strictly for the power steering.
On the 656 the larger main pump first goes to flow divider for steering and balance goes to aux valves. The smaller piggy pump is for hitch but if hitch is not raising the flow from hitch pump joins the flow from other pump to go to the aux valves. Separate relief valves for each system also. So, first thing to check is relief valve for aux valves located in the rear of aux valve block. If sounds like sucking air check return hose inside rear of tractor through 3rd arm link plate.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
