Re: 656 FYI
Posted by DV on May 07, 2014 at 11:23:34 from (216.107.167.226):
In Reply to: Re: 656 FYI posted by pete 23 on May 07, 2014 at 08:51:10:
The new piston and the old piston were the same size. I never did see an orifice in either piston. The old piston just seemed to have some drag on it. I replaced O-rings on old piston and even went as far as using a brake cylinder hone on the piston opening. I also used some real fine emery cloth to smooth up old piston. Still did not help. I put new piston and there was not any drag. An old mechanic buddy of mine said it should almost like there was no o-ring on it. and it does. As far as compression pressure,I believe they were the same. Hope this helps Doug
