Posted by mike1972chev on May 07, 2014 at 14:02:35 from (99.14.209.141):
In Reply to: Egged pinhole posted by Farmall4856 on May 07, 2014 at 13:35:31:
I had the EXACT problem last year . Someone had ran the clamp on the tube loose(previous owner of wide front I bought) and thats what happens!.
Just take a fine grinding disc and clean the area up,weld around the elongated sides of the hole,and then take a die grinder with a burr and SLOWLY work the welds until a new pin of the correct diameter just slides back through he hole.
Also,if you wanna "cheat" a little,you can find an aluminum/brass/carbon rod the same diameter as the pin and just stick it through the hole and wels around it. The weld will avoid those materials and help you make a "clean hole,but I like the FIRST way I did it the best. ;)
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
