Re: Egged pinhole
Posted by rankrank1 on May 07, 2014 at 18:37:00 from (198.228.228.175):
In Reply to: Egged pinhole posted by Farmall4856 on May 07, 2014 at 13:35:31:
Bad thing about boring oversize is that then you would need to bore all the other holes too if you want to move the axle width around. I know this does not happen very often, but I would not bore oversize just in case I ever wanted to change the width.
I would apply a little weld and then free hand shape back into a round shape with a carbide burr in either an air grinder of better yet one of those $25 electric ones from Harbor Freight works excellent. 6013 rod grinds almost like virgin steel if you use a stick welder so it is very easy to shape with handheld power tools. A wire feeder would also work well for this job but will be a tad harder to shape
FWIW: I probably use my welders for repairing oblong, worn, or sloppy holes as compared to any other single purpose. That an a cheapo electric die grinder from Harbor freight and a quality carbide burr and in business. (Hint: Use the biggest diameter carbide burr that you can fit in the hole. You will have more control and accuracy with a bigger diameter over a tiny diameter carbide burr. Small diameter prone to divoting where bigger diameter leaves smooth contours).
This post was edited by rankrank1 at 18:41:15 05/07/14 2 times.
