Re: Super C Fast Hitch control lever (up or down)?
Posted by mkirsch on May 08, 2014 at 04:58:50 from (65.199.189.6):
In Reply to: Super C Fast Hitch control lever (up or down)? posted by JakeBrakeIH on May 07, 2014 at 18:55:36:
Frankly I would go with whatever is most comfortable.
Push = up would be totally bass-ackward for me, for example.
Anything I've ever used was set up for pull back to lift, push forward to lower.
The logic being, you're looking backward watching the implement when you come to the end of the row. If you pushed to raise, you'd have to lean forward to reach, and most likely take your eyes of the implement unless you have long arms.
When you lower the implement, you're looking forward to make sure you're lined up with the next row, so the push action doesn't disrupt you like it would if you were lifting the implement.
On modern tractors with side consoles, it really doesn't matter because you don't have to reach, period.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
