Re: bearing for worm drive on narrow front end
Posted by John M on May 08, 2014 at 05:36:32 from (68.115.194.228):
In Reply to: Re: bearing for worm drive on narrow front end posted by pete 23 on May 07, 2014 at 18:50:42:
Not disagreeing with you Pete, but why does the same exact bearing the book called for at my IH dealer some years ago, have the exact same number, by the exact same manufacturer, that I got at my local parts store, cost almost 3 times less as the one at the IH dealer? I had the original with the IH number on it, crossed to the newest number, at the time. I couldnt visually see any difference in the original compared to the replacement. (this was on an M BTW, bigger and newer tractors may be different.) Same goes for seals. Heck, Ive even had someone tell me once the manifold studs were better at the dealer, because they came from the dealer, and would be right, whereas some from a local parts store wouldnt work, but both had the same supplier, Dorman I think.
This post was edited by John M at 06:43:00 05/08/14.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
