Re: Farmall Super H engine interchange info.
Posted by Jamie Svrcek on May 08, 2014 at 15:03:42 from (108.255.58.42):
In Reply to: Farmall Super H engine interchange info. posted by Jamie Svrcek on May 08, 2014 at 12:32:58:
Ok... To clarify. I have a complete block assembly (block, crank, rods, pistons, oil pump, pan, camshaft, timing gears, etc. etc.), aka "lower end" as opposed to the top of the engine.
I know it won't fit anything on the Super H. That's why I'm offering to trade it. What I don't know is what IH/Farmall engines will fit in the Super H.
Is there anything else that will bolt up from later production years? What does a Super H engine interchange with?
